Zum Hauptinhalt wechseln
Tommy Hilfiger Quartz Watch Band Link Replacement
Was du brauchst
  1. Tommy Hilfiger Quartz Watch Band Link Replacement, Band Link: Schritt 1, Bild 1 von 1
    • Place the watch on your wrist and approximate the number of links to be removed.
  2. Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 2, Bild 1 von 1
    • Identify the arrows located directly on the links and point them downwards in the south position.
  3. Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 3, Bild 1 von 3 Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 3, Bild 2 von 3 Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 3, Bild 3 von 3
    • Lay and secure the wristband on the watchband holder.
  4. Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 4, Bild 1 von 3 Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 4, Bild 2 von 3 Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 4, Bild 3 von 3
    • Align the tip of the pin pusher on the pin.
    • Begin tapping the hammer with force to push the link pin out.
  5. Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 5, Bild 1 von 2 Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 5, Bild 2 von 2
    • Set aside the link pins and links that have been removed from the watch.
  6. Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 6, Bild 1 von 3 Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 6, Bild 2 von 3 Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 6, Bild 3 von 3
    • In order to add links to the wristband, ensure that the arrows are pointing upwards in the north position.
    • Secure the wristband on the watchband holder.
  7. Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 7, Bild 1 von 2 Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 7, Bild 2 von 2
    • Align the link pins to be added on the holes that connect the desired link to the wristband.
  8. Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 8, Bild 1 von 3 Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 8, Bild 2 von 3 Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 8, Bild 3 von 3
    • Use the hammer to gently tap the link pins into the holes until the pin is completely resting in position.
  9. Tommy Hilfiger Quartz Watch Band Link Replacement: Schritt 9, Bild 1 von 1
    • Finally, place the watch on your wrist to determine if the links are secure and the fitment is comfortable.
    • If adjustments need to be made, refer to step 2 for the subtraction of links and step 6 for the addition of links.
Ziellinie
Ayush Theyyil
169 Reputation
1 Anleitung geschrieben
York University, Team F-3, Woodhouse Fall 2021 Mitglied von York University, Team F-3, Woodhouse Fall 2021
YORK-WOODHOUSE-F21SFG3
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 94
Insgesamt: 6,046
