Was du brauchst
Carefully fold the top and bottom open, revealing a ribbon cable connecting the two halves.
Unlock and disconnect the ribbon cable. Unlock by pulling the lock lever evenly on both sides, parallel to the board surface (not lift/pivot), in the direction of the ribbon cable.
When this ZIF (Zero Insertion Force) connector is properly unlocked, the ribbon cable should just fall right out of the socket (no need to pull with any strength).
Simply lift the RF shield off the unit.
When reinstalling, take note of the 6 fork-like interlocking clips around the edge of the shield, which should engage with the original positions.
