Zum Hauptinhalt wechseln
Toro 22-Inch Recycler Lawn Mower Blade Replacement
Was du brauchst
  1. Toro 22-Inch Recycler Lawn Mower Blade Replacement, Blade: Schritt 1, Bild 1 von 1
    • Place the lawnmower on its side.
    • Drain the gas, and make sure the lawnmower is tilted so the oil dip stick is down.
    • Oil can't seep into the air filter if the oil dip stick is down. Draining the gas tank is important to prevent gas from being spilled.
  2. Toro 22-Inch Recycler Lawn Mower Blade Replacement: Schritt 2, Bild 1 von 1
    • Remove the sparkplug wire from the sparkplug.
    • This will prevent the lawnmower from starting during the repair.
  3. Toro 22-Inch Recycler Lawn Mower Blade Replacement: Schritt 3, Bild 1 von 2 Toro 22-Inch Recycler Lawn Mower Blade Replacement: Schritt 3, Bild 2 von 2
    • Use a sturdy object, such as a brick or piece of wood, to keep the blade stable.
    • If using a brick or similar object, place it on the right side of the blade because we'll be turning the socket wrench to the left.
    • If using a piece of wood, place it across the bottom of the mower, so that the right side of the wood is wedged against the blade.
    • A small piece of wood is the most common way to stabilize the blade.
  4. Toro 22-Inch Recycler Lawn Mower Blade Replacement: Schritt 4, Bild 1 von 1
    • A socket wrench loosens the blade attachments. Attach a 5/8-inch bit to the socket wrench, and we're ready to loosen the nut.
  5. Toro 22-Inch Recycler Lawn Mower Blade Replacement: Schritt 5, Bild 1 von 1
    • Loosen the nut using a wrench with a 5/8-inch socket.
    • Consider wearing a pair of gloves for protection before using the wrench.
  6. Toro 22-Inch Recycler Lawn Mower Blade Replacement: Schritt 6, Bild 1 von 1
    • Remove the blade support and pull the blade.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 71
Insgesamt: 1,171
