Einleitung
This guide shows how to remove and replace the hydraulic fluid pump on the Toro Log Splitter 22618HD 2019 / LS-922.
Was du brauchst
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Flip the red engine ON/OFF switch to the OFF position.
Place a bucket underneath the device, below the pump to catch any hydraulic fluid drips.
Turn the trailer jack handle clockwise to raise the front of the device as far up as it will go.
Use a large flathead screwdriver to loosen the hose clamp.
Slide the hose clamp away from the pump and onto the hose.
Twist and pull the hose away from the pump to remove it.
Use zip ties, a bungie cord, rope, or something similar to tie the hose into an elevated position to avoid spills.
Plug the open end of the hose with a clean shop towel.
Use two adjustable wrenches to loosen the nut holding the input hose to the fitting on the right side of the pump.
Use an adjustable wrench to remove the fitting on the right side of the pump.
Use a pick tool to remove the O-ring from the input hose pump fitting, on the side that connects to the pump.
Use a 1/2 inch wrench to remove the four bolts securing the pump to the flex coupler housing.
Use a 2.5 mm hex key to loosen the pump-side flex coupler's set screw until the flex coupler moves freely on the shaft.
Pull the pump-side flex coupler away from the pump input shaft to remove it.
Keep track of the pump shaft key. Transfer it to the replacement pump only if the new part does not come with a new key.
Only the pump remains.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
