Einleitung
Follow this guide to replace the cutter head on a 2017 Toro Stump Grinder model 22615HD.
You will need a second person to assist with this repair.
Was du brauchst
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Tilt the machine so that it is resting on the handle with the cutter wheel raised.
Use a 14 mm socket to remove the fasteners securing the belt guard:
One 10 mm bolt
One 10 mm nut
Use a 9/16 inch socket to loosen the four nuts securing the bottom of the motor enough to allow the motor to slide freely. Do not remove the nuts.
Use a 1/2 inch wrench in combination with the socket wrench to hold the bolts in place.
Use a 1/2 inch wrench to loosen the two bolts behind the centrifugal clutch enough to allow the motor to slide freely. Do not remove the bolts.
Wrap a piece of tape around the upper half of the tensioner bolt to mark the location of the second nut.
Use a 9/16 inch wrench to loosen the nut on the lower half of the tensioner bolt until the motor can slide forward as much as possible.
Lift the drive belt up and away from the machine while rolling it towards the cutter head to gradually roll it off of the pulley.
Use an impact wrench with a 9/16 inch socket to remove the bolt and washer securing the centrifugal clutch to the spindle.
Use a jaw puller to extract the centrifugal clutch from the spindle:
Place the center screw so that it is in line with the center of the spindle.
Hook the jaws around the back edge of the clutch assembly.
Tighten the center screw until the centrifugal clutch is removed from the spindle.
Schritt 16 Remove the pulley
Achtung: Die Schritte 16-18 stammen von einer Anleitung, die derzeit bearbeitet wird.
Use a 1/8 inch hex key to remove the pulley set screw.
Use a universal puller to remove the pulley from the cutter wheel shaft:
Attach the universal puller to the pulley using the three bolts provided on the pulley.
Use a wrench to torque down the center screw to slowly loosen the pulley.
Use a 9/16 inch socket to remove the two bolts and washers securing the guard plate to the motor.
Use a 9/16 inch socket to remove the bolt and washer securing the guard plate to the frame.
Use a 5/8 inch wrench in combination with the 9/16 inch socket to hold the standoff in place.
Remove the bolt, washer, and standoff.
Use a 9/16 inch socket to remove the bolt and accompanying washer securing the guard plate to the frame.
Use a 5/8 inch socket to remove the nut securing the guard plate to the frame.
Use a 1/2 inch socket to remove the bolt next to the cutter wheel shaft securing the guard plate to the frame.
Use a 9/16 inch socket to remove the four bolts from the frame.
Lower the cutter wheel and bearings out from the frame.
Remove the cutter wheel and bearing assembly.
5 weitere Personen haben diese Anleitung absolviert.
