Zum Hauptinhalt wechseln
Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement
Was du brauchst
  1. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Turn off the power: Schritt 1, Bild 1 von 2 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Turn off the power: Schritt 1, Bild 2 von 2
    • Before you begin, ensure the machine is powered down and cool to the touch.
    • Turn the ignition switch to the off position.
  2. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Close the fuel valve: Schritt 2, Bild 1 von 2 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Close the fuel valve: Schritt 2, Bild 2 von 2
    • Flip the fuel cutoff valve switch into the off position.
  3. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Disconnect the spark plug: Schritt 3, Bild 1 von 2 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Disconnect the spark plug: Schritt 3, Bild 2 von 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Tilt the cutter wheel up: Schritt 4, Bild 1 von 1
    • Tilt the machine so that it is resting on the handle with the cutter wheel raised.
  5. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Remove the belt guard: Schritt 5, Bild 1 von 2 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Remove the belt guard: Schritt 5, Bild 2 von 2
    • Use a 14 mm socket to remove the fasteners securing the belt guard:
    • One 10 mm bolt
    • One 10 mm nut
  6. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 6, Bild 1 von 3 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 6, Bild 2 von 3 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 6, Bild 3 von 3
    • Remove the belt guard.
  7. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Remove the drive belt: Schritt 7, Bild 1 von 3 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Remove the drive belt: Schritt 7, Bild 2 von 3 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement, Remove the drive belt: Schritt 7, Bild 3 von 3
    • Use a 9/16 inch socket to loosen the four nuts securing the bottom of the motor enough to allow the motor to slide freely. Do not remove the nuts.
    • Use a 1/2 inch wrench in combination with the socket wrench to hold the bolts in place.
  8. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 8, Bild 1 von 1
    • Use a 1/2 inch wrench to loosen the two bolts behind the centrifugal clutch enough to allow the motor to slide freely. Do not remove the bolts.
  9. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 9, Bild 1 von 2 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 9, Bild 2 von 2
    • Wrap a piece of tape around the upper half of the tensioner bolt to mark the location of the second nut.
    • Use a 9/16 inch wrench to loosen the nut on the lower half of the tensioner bolt until the motor can slide forward as much as possible.
    • During reassembly, reference the tape to position the outer nut into the same location as before to ensure proper belt tension.
  10. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 10, Bild 1 von 2 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 10, Bild 2 von 2
    • Slide the engine towards the cutter blade to loosen the drive belt.
  11. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 11, Bild 1 von 3 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 11, Bild 2 von 3 Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 11, Bild 3 von 3
    • Lift the drive belt up and away from the machine while rolling it towards the cutter head to gradually roll it off of the pulley.
  12. Toro Stump Grinder SGR-13 22615HD 2017 Drive Belt Replacement: Schritt 12, Bild 1 von 1
    • Remove the drive belt.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Omiotek
68.107 Reputation
288 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 54
Insgesamt: 1,380
