Einleitung
Antennas in RC cars can be bent/broken during use. Fortunately, replacing the antenna on the Torque King is easy.
Was du brauchst
From the top view, remove each of the four pins that hold the casing in place.
Loosen the 10mm screw surrounded by the copper using a #2 Phillips head screwdriver.
Carefully slide the antenna out from under the screw and remove.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
