Zum Hauptinhalt wechseln
Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement
Was du brauchst
  1. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: Schritt 1, Bild 1 von 2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: Schritt 1, Bild 2 von 2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: Schritt 2, Bild 1 von 1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing Screws: Schritt 3, Bild 1 von 1
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing the Wheel: Schritt 4, Bild 1 von 1
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: Schritt 5, Bild 1 von 2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: Schritt 5, Bild 2 von 2
    • Pull the top half of the suspension to unclip it.
  6. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: Schritt 6, Bild 1 von 1
    • Remove the top clip along with the spring.
  7. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: Schritt 7, Bild 1 von 2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: Schritt 7, Bild 2 von 2
    • Pull up the bottom half of the suspension to unclip it.
Abschluss
Cal Poly, Team 6-30, Amido Winter 2015 Mitglied von Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
4 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
Hola buenas noches, me pueden hacer el favor de ayudarme a armar de nuevo la parte de la suspensión de la parte delantera, te go todas las piezas pero no recuerdo como van
Vivian giseli Barrero - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 268
