Ersatzteile
Kein Ersatzteil erforderlich.
  1. Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Du bist ein Genie!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. If needed, use the flathead screwdriver to gently pry the panel from the phone. Using your fingers, lift the panel from the device.
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  5. Use your fingers to gently detach the ribbon wire from the logic board. Use your fingers to gently detach the ribbon wire from the logic board. Use your fingers to gently detach the ribbon wire from the logic board.
    • Use your fingers to gently detach the ribbon wire from the logic board.
  6. Use the flathead screwdriver to pry the logic board and keypad from the device. Use the flathead screwdriver to pry the logic board and keypad from the device.
    • Use the flathead screwdriver to pry the logic board and keypad from the device.
  7. Use your thumb to peel the keypad from the device. Use your thumb to peel the keypad from the device.
    • Use your thumb to peel the keypad from the device.
Abschluss
Christopher
90 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 16-6, Maness Spring 2010 Mitglied von Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Mitglieder
16 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,505
