Einleitung
Use this guide to replace the mini front LCD screen.
  1. Open the phone so that it matches the photos to the left.
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations. The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Insert the head of a flathead screwdriver into the seam between the front cover and the phone. Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
  5. Using a small Phillips screwdriver, gently pry off the LCD screen from the board. Using a small Phillips screwdriver, gently pry off the LCD screen from the board.
    • Using a small Phillips screwdriver, gently pry off the LCD screen from the board.
  6. Using the head of the screwdriver, flip up the black tab connecting the ribbon-wire. Gently pull the LCD screen away from the board, the cable should come off with nearly no resistance.
    • Using the head of the screwdriver, flip up the black tab connecting the ribbon-wire.
    • Gently pull the LCD screen away from the board, the cable should come off with nearly no resistance.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Christopher
90 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 16-6, Maness Spring 2010 Mitglied von Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Mitglieder
16 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,811
