Einleitung
Removing the back may be the easiest thing to do, however do not forget about the screws hidden under the rubber foot pads!
Was du brauchst
Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
Loosen the back cover by using a plastic opening tool all the way around the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
