Zum Hauptinhalt wechseln
Toshiba CB35-C3300 Chromebook 2 Display Replacement
Was du brauchst
  1. Toshiba CB35-C3300 Chromebook 2 Display Replacement, Display: Schritt 1, Bild 1 von 1
    • Start by opening your Chromebook and orient the computer as shown.
  2. Toshiba CB35-C3300 Chromebook 2 Display Replacement: Schritt 2, Bild 1 von 1
    • Using the opening tool, start at one of the two top corners and pull the faceplate away from the display.
    • Use the opening tool to work your way all the way around the frame.
  3. Toshiba CB35-C3300 Chromebook 2 Display Replacement: Schritt 3, Bild 1 von 1
    • Using a Jimmy, carefully pop the bottom of the faceplate away from the display.
  4. Toshiba CB35-C3300 Chromebook 2 Display Replacement: Schritt 4, Bild 1 von 1
    • Remove the faceplate by pulling away from the keyboard.
  5. Toshiba CB35-C3300 Chromebook 2 Display Replacement: Schritt 5, Bild 1 von 1
    • Using an opening tool, start from one of the top corners of the screen and begin to pry it away from the top of the laptop.
    • Make sure that you can keep the foil on the Chromebook.
  6. Toshiba CB35-C3300 Chromebook 2 Display Replacement: Schritt 6, Bild 1 von 1
    • Using the Jimmy, remove the sticker holding the wire to this display.
  7. Toshiba CB35-C3300 Chromebook 2 Display Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the ribbon the display and remove the display from the Chromebook.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 153
