Zum Hauptinhalt wechseln
Einleitung
To complete this guide you will need patience and to work with a steady, gentle hand.
  1. Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool. Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Remove the 10 7.1 mm screws using Phillips #1 screwdriver. Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Loosen the back cover by using a plastic opening tool all the way around the device.
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Remove the back cover by gently lifting up on one side of the device. The easiest side to lift up on is the one with the removed rubber foot pads.
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Remove the tape holding the speaker wire to the battery on both sides using a small opening tool. Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver. Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire. Gently shaking the wire from left to right helps with the wire removal Gently shaking the wire from left to right helps with the wire removal
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Remove the battery by gently pulling on the bottom corners. Be careful to move the battery's wire under the speaker's wire.
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Locate the fan
    • Locate the fan
  10. Unscrew the 4 Phillip screws using a Phillips # 1 Screwdriver.
    • Unscrew the 4 Phillip screws using a Phillips # 1 Screwdriver.
    • These screws only loosen partially, they do not disconnect.
  11. The top wire is the fan's wire. Remove it by pulling it from the motherboard. The top wire is the fan's wire. Remove it by pulling it from the motherboard. The top wire is the fan's wire. Remove it by pulling it from the motherboard.
    • The top wire is the fan's wire. Remove it by pulling it from the motherboard.
  12. To remove the Wifi PCB wire lift up the hinged flap with your finger or with the aid of the spudger tool. After the flap is lifted, pull the wire up out of the connector socket. After the flap is lifted, pull the wire up out of the connector socket.
    • To remove the Wifi PCB wire lift up the hinged flap with your finger or with the aid of the spudger tool.
    • After the flap is lifted, pull the wire up out of the connector socket.
  13. Remove the headphone jack wire by pulling it out of the connector socket. Remove the headphone jack wire by pulling it out of the connector socket.
    • Remove the headphone jack wire by pulling it out of the connector socket.
  14. Remove the Phillip 3.6 mm screw from the fan using a  Phillips #1 screwdriver.
    • Remove the Phillip 3.6 mm screw from the fan using a Phillips #1 screwdriver.
  15. Lift up on the metal plate that hold the screws to start removing the fan.
    • Lift up on the metal plate that hold the screws to start removing the fan.
  16. Once lifted, you will notice that there are two wires tucked under plastic tunnels on the right side of the fan. Remove these wires. These wires require you to gently pull them out of there tunnel. Once the wires are removed the fan should be removed entirely.
    • Once lifted, you will notice that there are two wires tucked under plastic tunnels on the right side of the fan. Remove these wires.
    • These wires require you to gently pull them out of there tunnel.
    • Once the wires are removed the fan should be removed entirely.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
USF Tampa, Team S1-G121, Cagle Fall 2017 Mitglied von USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 Mitglieder
14 Anleitungen geschrieben
4 Kommentare
Where do you purchase a replacement fan?
Taylor Wilson - Antwort
Replacement fans are readily available on eBay for $5-15. Just search for: Toshiba CB35 Chromebook Fan
faba - Antwort
Can anyone explain why the battery needs to be removed? I don’t see how it would interfere with fan removal and replacement.
faba - Antwort
I was able to replace my fan without removing the battery (skip steps 5-8). Also able to skip steps 12 (Wifi PCB wire) and 13 (headphone jack wire) by carefully moving those wires out of the way while removing the fan. Note that when removing the heat sink, the the old thermal paste should be cleaned off and new paste applied (it may come on the new heat sink). The fan I bought on eBay was a C30 model with different heat sink, but I was able to swap the old heat sink onto the new fan. Final note when reassembling - the rubber footpads are NOT interchangeable. One has a small round hole and the other has a short slot.
faba - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 10
Insgesamt: 811
