Einleitung
This guide is really simple. It only involves unscrewing one screw!
  1. Remove the 2 rubber foot pads from the bottom with the small Plastic Opening tool.
    • Remove the 2 rubber foot pads from the bottom with the small Plastic Opening tool.
  2. Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
    • Loosen the back cover by using a plastic opening tool all the way around the device.
      • There are areas all along the sides of the device that help aid in this.
    • Remove the back cover by gently lifting up on one side of the device.
      • The easiest side to lift up on is the one with the removed rubber foot pads.
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
      • Gently shaking the wire from left to right helps with the wire removal
    • Remove the battery by gently pulling on the bottom corners.
      • Be careful to move the battery's wire under the speaker's wire.
    • Location of the SSD card
    • Remove the Phillips 3.6 mm screw using a Phillips #1 screwdriver.
    • Remove the yellow tape by slowly peeling it away at the bottom on the SSD.
    • Remove the SSD card from the motherboard by gently pulling up on the side where the screw originally was and out in the same direction.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jillian Thomas
Mitglied seit 14.10.2017
165 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G121, Cagle Fall 2017 Mitglied von USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 351
