Einleitung
This guide is really simple. It only involves unscrewing one screw!
Was du brauchst
Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
Loosen the back cover by using a plastic opening tool all the way around the device.
Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
Remove the SSD card from the motherboard by gently pulling up on the side where the screw originally was and out in the same direction.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
