Zum Hauptinhalt wechseln
Toshiba CB35-C3300 Chromebook 2 SSD Replacement
Was du brauchst
  1. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: Schritt 1, Bild 1 von 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: Schritt 2, Bild 1 von 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: Schritt 2, Bild 2 von 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: Schritt 3, Bild 1 von 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: Schritt 4, Bild 1 von 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: Schritt 4, Bild 2 von 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, SSD: Schritt 5, Bild 1 von 1
    • Remove the translucent yellow tape that connects the Wi-Fi card and the SSD.
    • Using a Phillips #1 screwdriver, remove the single screw connecting the SSD to the motherboard.
  6. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: Schritt 6, Bild 1 von 1
    • Gently grab the SSD and remove the card from the SSD slot on the motherboard, careful not to damage any of the connections on the motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 391
