Zum Hauptinhalt wechseln
Toshiba CB35-C3300 Chromebook 2 Speakers
Was du brauchst
  1. Toshiba CB35-C3300 Chromebook 2 Speakers, Back Cover: Schritt 1, Bild 1 von 2 Toshiba CB35-C3300 Chromebook 2 Speakers, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 2, Bild 1 von 2 Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 2, Bild 2 von 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 3, Bild 1 von 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 4, Bild 1 von 2 Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 4, Bild 2 von 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 Speakers, Battery: Schritt 5, Bild 1 von 2 Toshiba CB35-C3300 Chromebook 2 Speakers, Battery: Schritt 5, Bild 2 von 2
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 6, Bild 1 von 2 Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 6, Bild 2 von 2
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 7, Bild 1 von 3 Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 7, Bild 2 von 3 Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 7, Bild 3 von 3
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 8, Bild 1 von 2 Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 8, Bild 2 von 2
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Toshiba CB35-C3300 Chromebook 2 Speakers, Speakers: Schritt 9, Bild 1 von 2 Toshiba CB35-C3300 Chromebook 2 Speakers, Speakers: Schritt 9, Bild 2 von 2
    • Remove the 4 Phillip 6.3 mm screws from both the right and left speakers using Phllips 1 screwdriver.
  10. Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 10, Bild 1 von 1
    • Gently remove wire from the motherboard by pulling it out of the connector socket.
  11. Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 11, Bild 1 von 3 Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 11, Bild 2 von 3 Toshiba CB35-C3300 Chromebook 2 Speakers: Schritt 11, Bild 3 von 3
    • Remove the right and left speaker by lifting them up.
Abschluss
USF Tampa, Team S1-G121, Cagle Fall 2017 Mitglied von USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 183
