Zum Hauptinhalt wechseln
Einleitung
This guide will show you how to correctly replace your heat sink. This is a fairly straight forward replacement and does not require advanced knowledge or training.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the back cover of the Chromebook and locate the Heat sink and connected fan.
    • Remove the back cover of the Chromebook and locate the Heat sink and connected fan.
  2. Unscrew the 4 screws connecting the Heat Sink to the motherboard.
    • Unscrew the 4 screws connecting the Heat Sink to the motherboard.
  3. Unplug the three primary wires attached to the fan from the motherboard. Unplug the three primary wires attached to the fan from the motherboard.
    • Unplug the three primary wires attached to the fan from the motherboard.
  4. Ensure that all cables are detached.
    • Ensure that all cables are detached.
  5. Carefully remove the Heat sink and fan and set aside.
    • Carefully remove the Heat sink and fan and set aside.
Abschluss
Gabriel Bryan
303 Reputation
2 Anleitungen geschrieben
IUPUI, Team S6-G6, Wilson Fall 2018 Mitglied von IUPUI, Team S6-G6, Wilson Fall 2018
IUPUI-WILSON-F18S6G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 107
