Einleitung
This guide will address the battery replacement in the Toshiba CB35-3350 Chromebook 2. Replacing the battery may be necessary if it has a short lifespan or is having trouble charging. Replacing the battery is expected to have an improved lifespan and may have better-charging capabilities. Precautions when replacing the battery: keep it out of the sunlight, and if it’s damaged, wear gloves when changing it. Be sure to use proper disposal methods by taking it to a facility that offers battery recycling. Screen Surgeons has a helpful video showing how to replace the battery.
Was du brauchst
Remove the Phillips #0 screws from the back of the laptop.
Use your hands and an iFixit opening tool to remove the back of the laptop.
Remove the four Phillips #0 screws from the speakers.
Move the speakers out of the way.
Unplug the wires connecting the battery to the motherboard.
Remove the battery from the laptop.
