Einleitung
Over time, speaker quality can degrade for a variety of reasons. Replacing the speakers will fix most issues involving sound and sound quality.
Was du brauchst
Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
