Einleitung
A touchpad is extremely important in the use of laptops. The touchpad can often cause the cursor to not move in the right direction, or not at all. When these are continual problems, the best solution is to replace the faulty touchpad with a new one.
Was du brauchst
Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
Detach the ribbon cable connected to the motherboard by gently pulling near the top fold.
Detach the ribbon cable connected to the touch pad by gently pulling near the bottom fold.
Remove all four 3.70mm screws around the edges of the touchpad using a Phillips #0 screwdriver.
Use the spudger to push up on the metal cover below the touch pad until it reaches 90 degrees then pull up to detach.
Push down on the bottom right corner and slowly lift up in the upper right hand corner until the touch pad comes out.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Thanks for this guide! Worked perfectly.
This is great! I was able to save our school the cost of a replacement computer!
