Einleitung
In this guide we plan to remove the internal speakers from the Toshiba ChromeBook and replace them with new ones.
Was du brauchst
Using a Y1 screw driver head remove all ten .9mm screws from the back cover
Set the screws aside in preparation for reassembly
Remove the back cover by placing a prying tool in the SD slot and popping the clips out of place.
Unscrew the battery by using a J1 screw driver head, and place the four .7mm screws off to the side
Using a pry tool, pop the battery connector out of place and gently lift the battery upward.
Remove the right side speaker by popping it out of place with your finger
Follow the speaker wire along the clips underneath the battery until you reach the left hand speaker
Unplug the connector wiring the speaker to the mother board.
Pop the speaker out of the computer, similar to the method used in the previous step.
2 weitere Personen haben diese Anleitung absolviert.
