Zum Hauptinhalt wechseln
Toshiba Dynabook T552-58G Hard Drive Replacement
Was du brauchst
  1. Toshiba Dynabook T552-58G Hard Drive Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn the Toshiba Dynabook T552-58G so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove the 10 screws located on the back panel of the Toshiba Dynabook T552-58G using a PH 0 screwdriver.
    • Each screw will be 5.3 mm long.
  3. Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 3, Bild 1 von 3 Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 3, Bild 2 von 3 Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Remove the black screw using the J0 screwdriver. This is located by the top right foot of the device.
    • This will allow removal of the hard drive cover.
    • This screw will not come out of the hard drive cover.
  4. Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the single screw located below the hard drive using the J0 screwdriver. This screw is 5.3 mm long.
  5. Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 5, Bild 1 von 3 Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 5, Bild 2 von 3 Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
    • Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
  6. Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 6, Bild 1 von 3 Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 6, Bild 2 von 3 Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Slowly lift the back panel away from the computer.
    • There should be some resistance.
    • Once lifted, carefully remove the back panel.
  7. Toshiba Dynabook T552-58G Hard Drive Replacement, Hard Drive: Schritt 7, Bild 1 von 1
    • The hard drive is located in the under the L-shaped panel on the back of the computer.
  8. Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Carefully push the hard drive to the left
  9. Toshiba Dynabook T552-58G Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Gently lift the hard drive using your fingers.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 12
Letzte 30 Tage: 24
Insgesamt: 582
