Einleitung
Fix your computer’s screen with ease by following this guide.
If your screen is busted, malfunctioning, or just needs to be replaced, this guide will assist you through the process. For best results, all steps should be followed.
Was du brauchst
Using a PH 00 screwdriver, unscrew the four screws in each corner of the screen cover. Each screw is 3.3 mm long.
Using a PH 0 screwdriver, unscrew the screws connecting the front cover to the screen. There are two and each screw is 3.4 mm long.
Using your fingers, pull the wires from the backing of the front cover.
Disconnect the wire from the front cover.
Using a PH 0 screwdriver, remove the screws from each side of the screen. There are a total of six screws. Each screw is 3.2 mm long.
