Zum Hauptinhalt wechseln
Toshiba Dynabook T552-58G Space Bar Replacement
  1. Toshiba Dynabook T552-58G Space Bar Replacement, Space Bar: Schritt 1, Bild 1 von 1
    • The space bar is located on the bottom of the keyboard.
  2. Toshiba Dynabook T552-58G Space Bar Replacement: Schritt 2, Bild 1 von 2 Toshiba Dynabook T552-58G Space Bar Replacement: Schritt 2, Bild 2 von 2
    • Gently pry the broken space bar up with from the back with your finger.
  3. Toshiba Dynabook T552-58G Space Bar Replacement: Schritt 3, Bild 1 von 1
    • You should now see the key retainer.
    • Do not remove anything else because this is crucial for replacing the key.
  4. Toshiba Dynabook T552-58G Space Bar Replacement: Schritt 4, Bild 1 von 3 Toshiba Dynabook T552-58G Space Bar Replacement: Schritt 4, Bild 2 von 3 Toshiba Dynabook T552-58G Space Bar Replacement: Schritt 4, Bild 3 von 3
    • Gently lift up the bottom metal prongs.
    • Insert the two ends of the prong into the small metal loops located at the top of the key pad.
    • Gently press the key down until you hear a click.
Ziellinie
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 16
Insgesamt: 519
