Zum Hauptinhalt wechseln
Toshiba Encore Mini Battery Replacement
Was du brauchst
  1. Toshiba Encore Mini Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Encore Mini Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Battery Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Battery Replacement: Schritt 4, Bild 1 von 2 Toshiba Encore Mini Battery Replacement: Schritt 4, Bild 2 von 2
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Battery Replacement: Schritt 5, Bild 1 von 1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Tacoma, Team 1-3, Liner SU 2015 Mitglied von UW Tacoma, Team 1-3, Liner SU 2015
UWT-LINER-SU15S1G3
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Be sure to remove any SD cards you have first.
ecw0647 - Antwort
But where do i buy the battery?
sissyhana - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 4,006
