Einleitung
The following guide shows detailed steps to remove the onboard speaker from a Toshiba Encore Mini. Be sure to back up data to an external device before attempting any component replacement.
Was du brauchst
Using the flat end of the spudger, gently pry open the back case from the rest of the device.
Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
Carefully use the metal spudger to remove the speaker from the frame of the phone.
