Was du brauchst
Use the metal spudger to create a gap between the back cover and the device.
Use the nylon spudger to completely separate the back of the device.
Take the nylon spudger around the outside of the device cover until it comes free.
Use the Phillips head PH0 to remove the 7 battery screws.
The 5 side screws measure 3.5mm.
The 2 top and bottom screws measure 4.5 mm.
To disconnect the cable, use the fine tweezers to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
Remove the colored power cable from its connector.
To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
Alternating from one side to the other, gently “walk” the connector out of its socket.
2 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Hi can I get Battery for Toshiba Encore 2 WT8-B?
Thanks
Regards
Dr Ravindra
Hi friends can I get Battery for Toshiba Encore 2 WT8-B
Thanks
Regards
Dr Ravindra
who can I replacement socket charging for toshiba tablet WT8-A
