Was du brauchst
Use the metal spudger to create a gap between the back cover and the device.
Use the nylon spudger to completely separate the back of the device.
Take the nylon spudger around the outside of the device cover until it comes free.
Use the Phillips head PH0 to remove the 7 battery screws.
The 5 side screws measure 3.5mm.
The 2 top and bottom screws measure 4.5 mm.
To disconnect the cable, use the fine tweezers to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
Remove the colored power cable from its connector.
To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
Alternating from one side to the other, gently “walk” the connector out of its socket.
Use the soldering iron to melt the metal connection from the motherboard to the audio jack.
Use the fine pointed tweezers to pull the audio jack away from the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
