Zum Hauptinhalt wechseln
Toshiba Equium M70 Faulty Graphics
Was du brauchst
  1. Toshiba Equium M70 Faulty Graphics, Toshiba Equium M70 Faulty Graphics: Schritt 1, Bild 1 von 1
    • This is a complete top half strip down to fix (takes me less than 30 minutes)
  2. Toshiba Equium M70 Faulty Graphics: Schritt 2, Bild 1 von 1
    • this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
  3. Toshiba Equium M70 Faulty Graphics: Schritt 3, Bild 1 von 1
    • cut a thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
  4. Toshiba Equium M70 Faulty Graphics: Schritt 4, Bild 1 von 1
    • Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
  5. Toshiba Equium M70 Faulty Graphics: Schritt 5, Bild 1 von 1
    • THen apply more thermal paste to the top of the shim
  6. Toshiba Equium M70 Faulty Graphics: Schritt 6, Bild 1 von 1
    • The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
  7. Toshiba Equium M70 Faulty Graphics: Schritt 7, Bild 1 von 1
    • This is the CPU with the new alloy shim fitted.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Terry Sim
207 Reputation
1 Anleitung geschrieben
Ein Kommentar
Pros: Very good hi-res pictures, well explained.
Cons: The disassembly instructions are missing
Nicola Nascimento - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 2,037
