Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide serves as a prerequisite step for all of the other repair guides. Removing the back panel is necessary to access any of the hardware within the tablet.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the SD card from the SD card slot.
    • Remove the SD card from the SD card slot.
  2. Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device. Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet. Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out. Be careful not to rip the wires out of the white connector piece. Be careful not to rip the wires out of the white connector piece.
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
Abschluss
Andrew Gillis
564 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 14-26, Maness Fall 2014 Mitglied von Cal Poly, Team 14-26, Maness Fall 2014
CPSU-MANESS-F14S14G26
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 77
