Einleitung
This guide will teach you how to access your tablet's battery, and how to remove it. Reverse these steps with a new battery to replace a broken one.
Was du brauchst
Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
Using a #00 Phillips screwdriver, remove the following screws:
Five 3mm Phillips #00 screws
12 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
My tablet won't come on what do i do? It was working yesterday with no problem when I plugged it in this morning to charge it while I was gone when I came back it would come on at all . It felt hot.
Thank you kindly. It took 20 minutes total.
My tablet comes but it's want to go to main screen
Ça m'a pris 20 min.La batterie est HS.Comment la brancher directement sur électricité ???!!?
