Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If the front facing camera on your Toshiba Excite 10 AT300 is now longer functioning, replacement isn't difficult and this guide will give you the step by step procedure. It involves removing a single copper foil wire.
  1. Remove the SD card from the SD card slot.
    • Remove the SD card from the SD card slot.
  2. Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device. Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet. Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out. Be careful not to rip the wires out of the white connector piece. Be careful not to rip the wires out of the white connector piece.
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
  4. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  5. Using a #00 Phillips screwdriver, remove the following screws: Five 3mm Phillips #00 screws
    • Using a #00 Phillips screwdriver, remove the following screws:
    • Five 3mm Phillips #00 screws
  6. Gently lift the battery, pulling away from the tab holding it in place at the bottom. While holding the battery up, use a pair of tweezers to remove the battery cable from its connector. While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
    • Gently lift the battery, pulling away from the tab holding it in place at the bottom.
    • While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
  7. Using tweezers, pull the copper foil up from the back of the camera. It should peel up easily. Warning: Be careful to avoid ripping the foil.
    • Using tweezers, pull the copper foil up from the back of the camera. It should peel up easily.
    • Warning: Be careful to avoid ripping the foil.
  8. Carefully remove the ribbon cable from the housing by pulling gently upwards on the sides of the cable housing. The cable should come straight up off of its housing.
    • Carefully remove the ribbon cable from the housing by pulling gently upwards on the sides of the cable housing. The cable should come straight up off of its housing.
Abschluss
Gus Holz
297 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-26, Maness Fall 2014 Mitglied von Cal Poly, Team 14-26, Maness Fall 2014
CPSU-MANESS-F14S14G26
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 7
Insgesamt: 553
