Zum Hauptinhalt wechseln
Toshiba HD-A2 Drive Belt Replacement
Was du brauchst
  1. Toshiba HD-A2 Drive Belt Replacement, Top Panel: Schritt 1, Bild 1 von 1
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Toshiba HD-A2 Drive Belt Replacement: Schritt 2, Bild 1 von 2 Toshiba HD-A2 Drive Belt Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Toshiba HD-A2 Drive Belt Replacement: Schritt 3, Bild 1 von 1
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  4. Toshiba HD-A2 Drive Belt Replacement, Optical Drive: Schritt 4, Bild 1 von 3 Toshiba HD-A2 Drive Belt Replacement, Optical Drive: Schritt 4, Bild 2 von 3 Toshiba HD-A2 Drive Belt Replacement, Optical Drive: Schritt 4, Bild 3 von 3
    • Remove five 6mm Phillips screws with a Phillips #2 screwdriver.
    • The 2 screws on the right of the cartridge are better shown in the second and third photos.
  5. Toshiba HD-A2 Drive Belt Replacement: Schritt 5, Bild 1 von 2 Toshiba HD-A2 Drive Belt Replacement: Schritt 5, Bild 2 von 2
    • Remove the remaining four 6mm Phillips screws.
  6. Toshiba HD-A2 Drive Belt Replacement: Schritt 6, Bild 1 von 3 Toshiba HD-A2 Drive Belt Replacement: Schritt 6, Bild 2 von 3 Toshiba HD-A2 Drive Belt Replacement: Schritt 6, Bild 3 von 3
    • Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
  7. Toshiba HD-A2 Drive Belt Replacement: Schritt 7, Bild 1 von 2 Toshiba HD-A2 Drive Belt Replacement: Schritt 7, Bild 2 von 2
    • Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
  8. Toshiba HD-A2 Drive Belt Replacement: Schritt 8, Bild 1 von 1
    • Using your fingers, gently pull off the wires.
  9. Toshiba HD-A2 Drive Belt Replacement: Schritt 9, Bild 1 von 2 Toshiba HD-A2 Drive Belt Replacement: Schritt 9, Bild 2 von 2
    • Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
    • Be careful not to rip the tape attaching the green circuit boards together.
  10. Toshiba HD-A2 Drive Belt Replacement: Schritt 10, Bild 1 von 2 Toshiba HD-A2 Drive Belt Replacement: Schritt 10, Bild 2 von 2
    • Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
  11. Toshiba HD-A2 Drive Belt Replacement: Schritt 11, Bild 1 von 2 Toshiba HD-A2 Drive Belt Replacement: Schritt 11, Bild 2 von 2
    • Using your hands, gently lift the lid and carefully place it aside.
  12. Toshiba HD-A2 Drive Belt Replacement: Schritt 12, Bild 1 von 3 Toshiba HD-A2 Drive Belt Replacement: Schritt 12, Bild 2 von 3 Toshiba HD-A2 Drive Belt Replacement: Schritt 12, Bild 3 von 3
    • Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
  13. Toshiba HD-A2 Drive Belt Replacement, Drive Belt: Schritt 13, Bild 1 von 3 Toshiba HD-A2 Drive Belt Replacement, Drive Belt: Schritt 13, Bild 2 von 3 Toshiba HD-A2 Drive Belt Replacement, Drive Belt: Schritt 13, Bild 3 von 3
    • Slide out the disc tray. If it's stuck, turn the white gear to the right to release the tray.
  14. Toshiba HD-A2 Drive Belt Replacement: Schritt 14, Bild 1 von 1
    • The drive belt is the black rubber band.
  15. Toshiba HD-A2 Drive Belt Replacement: Schritt 15, Bild 1 von 2 Toshiba HD-A2 Drive Belt Replacement: Schritt 15, Bild 2 von 2
    • Using your fingers, gently remove the drive belt.
    • If you have difficulty using your fingers, use a prying tool.
Abschluss
Nouriyah Saleh
800 Reputation
6 Anleitungen geschrieben
UC Davis, Team S11-G1, Lore Fall 2018 Mitglied von UC Davis, Team S11-G1, Lore Fall 2018
UCD-LORE-F18S11G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 406
