Einleitung
Does your DVD player not play discs at all? Use this guide to replace the optical drive in your device.
Was du brauchst
Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
Using your hand, gently lift the black top panel and safely place it off to the side.
Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
