Einleitung
If you find that your disc isn't reading despite no scratches, use this guide to remove and replace the optical lens.
Was du brauchst
Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
Using your hand, gently lift the black top panel and safely place it off to the side.
Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
The optical lens will be resting aside the small green circuit board.
Using a prying tool, wedge the edge of the tool underneath the end of the optical lens closest to the green circuit board. Gently push down to pop off the optical lens.
