Zum Hauptinhalt wechseln
Toshiba HD-A2 Power Button Replacement
Was du brauchst
  1. Toshiba HD-A2 Power Button Replacement, Power Button: Schritt 1, Bild 1 von 3 Toshiba HD-A2 Power Button Replacement, Power Button: Schritt 1, Bild 2 von 3 Toshiba HD-A2 Power Button Replacement, Power Button: Schritt 1, Bild 3 von 3
    • Using your hands, pop off the black console from each hinge surrounding the case.
    • There are a total of 7 hinges.
  2. Toshiba HD-A2 Power Button Replacement: Schritt 2, Bild 1 von 1
    • With the inside of the console facing up, the power button will be encased in clear plastic located on the right side of the console.
  3. Toshiba HD-A2 Power Button Replacement: Schritt 3, Bild 1 von 2 Toshiba HD-A2 Power Button Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the single screw holding the power button to the console.
    • After taking out the screw, the small piece of metal underneath will come loose. Carefully place this part aside.
  4. Toshiba HD-A2 Power Button Replacement: Schritt 4, Bild 1 von 1
    • Using your fingers, gently pull out the power button. You can push it from the outside to help loosen it from its hinges.
Abschluss
Nouriyah Saleh
800 Reputation
6 Anleitungen geschrieben
UC Davis, Team S11-G1, Lore Fall 2018 Mitglied von UC Davis, Team S11-G1, Lore Fall 2018
UCD-LORE-F18S11G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 149
