Einleitung
If you find that your power button is jammed or isn't working, use this guide to remove and replace the power button.
Was du brauchst
Using your hands, pop off the black console from each hinge surrounding the case.
With the inside of the console facing up, the power button will be encased in clear plastic located on the right side of the console.
Use a Phillips #1 screwdriver to remove the single screw holding the power button to the console.
Using your fingers, gently pull out the power button. You can push it from the outside to help loosen it from its hinges.
