Einleitung
Use this guide to replace the top panel of your device.
Was du brauchst
Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
Using your hand, gently lift the black top panel and safely place it off to the side.
Fast fertig!
Abschluss
