Einleitung
This guide will show you the easiest way to replace your keyboard.
Was du brauchst
Located on the bottom of the laptop, find the two tabs shown in the picture and push both of them outwards away from the battery.
While pushing the tabs outwards, push on the raised bumps on the battery away from the laptop.
Locate the five 1.2 mm Phillips # 000 screws inside of the battery housing.
Using a Phillips head #000 screwdriver, carefully remove the five 1.2mm screws.
Lift the keyboard gently away from the computer.
Do not attempt to fully remove the keyboard, as it is attached to the laptop by a ribbon cable.
Locate the ribbon wire under the keyboard. Slide the white tabs forward and the keyboard will come loose.
3 weitere Personen haben diese Anleitung absolviert.
