Einleitung
This guide will showcase how to easily replace the WiFi Card.
Was du brauchst
Locate the two 1.2mm philips #000 screws holding the bottom plate onto the laptop.
Locate the WiFi card by following the black and white wiring inside of the laptop.
Use a Phillips head #000 screwdriver to remove the two 1.2mm screws holding the card into the laptop.
3 weitere Personen haben diese Anleitung absolviert.
