Zum Hauptinhalt wechseln
Toshiba NB205 N330PK Key Cleaning
Was du brauchst
  1. Toshiba NB205 N330PK Key Cleaning, Toshiba NB205 N330PK Key Cleaning: Schritt 1, Bild 1 von 1
    • Using the spudger, gently pry the desired key up on one side. This will release the key.
    • The key is held in place by very small plastic pieces. Improper removal or installation may damage key permanently and require entire keyboard replacement.
  2. Toshiba NB205 N330PK Key Cleaning: Schritt 2, Bild 1 von 2 Toshiba NB205 N330PK Key Cleaning: Schritt 2, Bild 2 von 2
    • Use a brush to remove debris and use a cleaner cloth to remove residue.
    • Similarly, remove debris and residue from the area of the keyboard where the key was originally seated.
  3. Toshiba NB205 N330PK Key Cleaning: Schritt 3, Bild 1 von 1
    • Once clean, set the key above its original position and firmly press it back into place.
    • If cleaned and installed properly the key should depress smoothly and spring back to normal position once released.
Abschluss
This is a complete guide to removing a key and cleaning the area before replacement.
Mason McCaskill
1.000 Reputation
9 Anleitungen geschrieben
Clemson, Team 14-2, Benson Fall 2013 Mitglied von Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 490
