Was du brauchst
Start by first removing the battery.
Move the first release switch to the right position.
Move the second release switch to the right position while pulling the battery towards the top of the netbook.
Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
Using the bit driver and a Phillips #0 Bit, remove the two circled screws labelled F6. (These hold the keyboard) one screw may be under a rubber stopper
Carefully lift off the power bar assembly for access to the button and receiver.
Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
Reach under the keyboard and disconnect the electrical connection.
Lift the broken keyboard off.
Reattach the new electrical connection into the old connection location.
Place the keyboard into the original location starting with the bottom first.
Gently press the keyboard down to secure it into its original location.
Eine weitere Person hat diese Anleitung absolviert.
