Ersatzteile
Kein Ersatzteil erforderlich.
Start by first removing the battery.
Move the first release switch to the right position.
Move the second release switch to the right position while pulling the battery towards the top of the netbook.
Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
Carefully lift off the power bar assembly for access to the button and receiver.
Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
Reach under the keyboard and disconnect the electrical connection.
Lift the keyboard assembly out and away from the netbook.
Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool.
Remove this electrical connection with tweezers.
Use a spudger to gently pry the bezel from retaining clips.
This will allow the keyboard bezel to lift off of the body.
Use a bit driver and a Phillips #0 bit to remove the two retaining screws on the speaker assembly.
Lift out the old speaker assembly.
