Zum Hauptinhalt wechseln
Toshiba Portege 3110CT Laptop Screen Replacement
Was du brauchst
  1. Toshiba Portege 3110CT Laptop Screen Replacement, Laptop Screen: Schritt 1, Bild 1 von 1
    • Begin by removing the battery and flipping the laptop over to see the screws
    • Using a phillips head screwdriver to remove the screws that secure the back
  2. Toshiba Portege 3110CT Laptop Screen Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop back over and open it up carefully
    • Lift up the bottom panel where the mouse click buttons are
    • Lift up slowly as simply flip it up and rest it on the keyboard as not to damage the ribbon cable connecting it
    • Using the spudger disconnect the ribbon cable connected to the bottom of the panel
  3. Toshiba Portege 3110CT Laptop Screen Replacement: Schritt 3, Bild 1 von 1
    • Using the same size phillips as before remove the two screws that hold the keyboard in place
    • Then simply lift the keyboard up and slide it down and out
  4. Toshiba Portege 3110CT Laptop Screen Replacement: Schritt 4, Bild 1 von 1
    • Using the phillips remove the 3 screws that hold the screen mount to the rest of the keyboard
    • Once you remove the final screw be careful as the screen will want to fall back to prevent damage
  5. Toshiba Portege 3110CT Laptop Screen Replacement: Schritt 5, Bild 1 von 1
    • Pull the screen off the rest of the laptop and flip it over
    • Using the phillips screw driver remove the final 3 screws securing the screen
Abschluss
Ashley Furtado
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 6-4, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 6-4, Martin Fall 2016
UMASSD-MARTIN-F16S6G4
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 487
