Zum Hauptinhalt wechseln
Toshiba Portege M300 Hard Drive Replacement
Was du brauchst
  1. Toshiba Portege M300 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Portege M300 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Portege M300 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 Toshiba Portege M300 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 Toshiba Portege M300 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Turn the computer over onto the back.
    • Use a Phillips #1 screwdriver to remove the screw from the hard drive cover.
    • Lift and remove the cover.
  5. Toshiba Portege M300 Hard Drive Replacement: Schritt 5, Bild 1 von 3 Toshiba Portege M300 Hard Drive Replacement: Schritt 5, Bild 2 von 3 Toshiba Portege M300 Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Carefully remove the hard drive from the IDE cable by pulling on the black connector.
    • Do not pull the orange cable.
  6. Toshiba Portege M300 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Portege M300 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Remove the two gray rubber covers from both ends of the hard drive.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Alison Wendt
135 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 21-51, Johann Spring 2013 Mitglied von Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 16
Insgesamt: 2,208
