Einleitung
This guide will go through the steps needed to install a new wireless card.
Ersatzteile
Keine Ersatzteile angegeben.
Slide the lock on the left side to the unlock position.
Slide the lock on the right side to the unlock position until there is a clicking sound.
Turn the computer onto the back.
Remove the Phillips #0 screw that secures the cover to the rest of the device.
One 5.1 mm coarse thread screw.
Pull the cover forward to release it.
Use a Phillips #1 screwdriver to remove the two screws on opposite corners of the wireless card.
Two 4.0 mm coarse thread screws.
Use a plastic opening tool to gently lift the wireless card out while leaving the wire connected.
Hold the edges of the wireless card and carefully disconnect the black 3 pin connector.
