Einleitung
In this guide, you will learn how to replace a battery that doesn't charge properly or anymore. This guide will also teach you what the proper and necessary tools are for this repair.
  1. Make sure the battery lock switch is switched to the unlocked position. Slide the battery release switch to the up.
    • Make sure the battery lock switch is switched to the unlocked position.
    • Slide the battery release switch to the up.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Using your hand, lift up the battery. The battery release switch must be held in place.
    • Using your hand, lift up the battery.
    • The battery release switch must be held in place.
Abschluss
Varsha Roopreddy
1 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 4-17, Maness Spring 2013 Mitglied von Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 725
