Zum Hauptinhalt wechseln
Toshiba Portege M400 CD/DVD Drive Replacement
Was du brauchst
  1. Toshiba Portege M400 CD/DVD Drive Replacement, CD/DVD Drive: Schritt 1, Bild 1 von 1
    • Make sure your computer is securely latched and closed.
    • Locate the CD drive on the right side of your Toshiba Portege M400 laptop and find a small hole right next to the CD drive button.
  2. Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 2, Bild 2 von 2
    • Using the tweezers, insert them into the small hole next to the CD drive button.
  3. Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 3, Bild 2 von 2
    • Push the tweezers back into the hole and grab the CD drive door with the other tweezers' appendage.
    • Pull the CD door out carefully to remove the broken or jammed disk.
    • Note: If the CD door still does not open, move on to the next step to see how to remove the CD drive entirely.
  4. Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 4, Bild 1 von 1
    • Flip the laptop over so its on its face.
  5. Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 5, Bild 1 von 3 Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 5, Bild 2 von 3 Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 5, Bild 3 von 3
    • Locate screw as seen on picture
    • Using #1 Philips head screwdriver remove the 3.8mm screw.
  6. Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 6, Bild 2 von 2
    • Locate the lock switch in the center of the laptop.
    • Locate the tab on the end of the end of the CD Drive.
  7. Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 7, Bild 1 von 3 Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 7, Bild 2 von 3 Toshiba Portege M400 CD/DVD Drive Replacement: Schritt 7, Bild 3 von 3
    • Push down on the lock tab and pull on the CD tab simultaneously.
    • Keep pulling on the CD drive tab until the CD drive comes all the way out.
Abschluss
Cal Poly, Team 4-17, Maness Fall 2012 Mitglied von Cal Poly, Team 4-17, Maness Fall 2012
CPSU-MANESS-F12S4G17
1 Mitglied
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 1,103
