Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
In this guide, you will learn how to disassemble the broken/damaged screen from the rest of the laptop, allowing you to replace it for a new one. This guide will also teach you what the proper and necessary tools are for this repair.
  1. Using a plastic opening tool, remove all stickers covering the screws. Note: There are 6 locations; 2 at the top corners, 2 at the bottom corners, and 2 more at the bottom, towards the center of the screen.
    • Using a plastic opening tool, remove all stickers covering the screws.
    • Note: There are 6 locations; 2 at the top corners, 2 at the bottom corners, and 2 more at the bottom, towards the center of the screen.
  2. Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver. Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver.
    • Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver.
  3. With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop. Slowly pull the plastic panel from the entire laptop.
    • With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop.
    • Slowly pull the plastic panel from the entire laptop.
  4. Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen. Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
    • Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
  5. Carefully lift up the screen from the rest of the laptop and let it lean towards you, as it is still attached to cords and other wirings. Remove all white tape that hold the cords and wirings together.
    • Carefully lift up the screen from the rest of the laptop and let it lean towards you, as it is still attached to cords and other wirings.
    • Remove all white tape that hold the cords and wirings together.
  6. Note: Some parts need unplugging. Slowly and carefully unplug each of the components. Note: Some parts need unplugging. Slowly and carefully unplug each of the components.
    • Note: Some parts need unplugging. Slowly and carefully unplug each of the components.
  7. At this point, the screen should be completely disconnected from the rest of the laptop.
    • At this point, the screen should be completely disconnected from the rest of the laptop.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Varsha Roopreddy
22 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 4-17, Maness Spring 2013 Mitglied von Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 1,185
